Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-08-2005, 10:29 AM
RodeoJunkie RodeoJunkie is offline
squaling belts!!!!!!!!!!!
I just replaced the timing belt and all the outside belts. When I cranked it the first 5 or 6 times everything was great "NO" noise. Now when I crank it, for the first 3 to 4 seconds the belt(s) scream. I think I have them tight enough. They will flex down aprox 1/4 of an inch. I didn't want to make them too tight in fear of screwing up bearings in ac/ps/alt.
Can anyone give me some pointers? I have sprayed some STP belt dressing on the bottoms of the belts, it prevents it for a while? Like I said, once it cranks it stops? Please Help. Should I go tighter?
2003 Harley Davidson Firefighter Edition
1999 Ford F-150 Lariat
1997 Isuzu Rodeo 4WD
1955 Chevy 2DR Sedan Bel-Air "sweet"
Old 03-08-2005, 11:14 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: squaling belts!!!!!!!!!!!
Maybe it is too tight?
Bearings going on something?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-08-2005, 01:02 PM
Re: Re: squaling belts!!!!!!!!!!!
I wondered that too, but if the bearings are going out why does it only do it at start up?
Old 03-08-2005, 01:10 PM
iskiuskiweski's Avatar
iskiuskiweski iskiuskiweski is offline
Send a message via Yahoo to iskiuskiweski
I have found that they sometimes stretch after the initial run. Sometimes you have to retighten them after the get the initial stretch out. I have had to tighten them before a couple times before it finaly stopped.
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k
Old 03-08-2005, 01:29 PM
Re: Re: Re: squaling belts!!!!!!!!!!!
I'm on the way out the door to work on it now. I've got radiator flush that I've got to get empty out and replace with antifreeze. I'll tighten these belts up a little and see if this helps...........
Old 03-08-2005, 07:24 PM
Talking Re: Re: Re: Re: squaling belts!!!!!!!!!!!
Tightening up is all they needed. I thought I had them tight enough but I guess not. So if your belts are whinning (like mine were) all you need to do is tighten them a little.
Old 03-10-2005, 06:40 PM
Cat Fuzz Cat Fuzz is offline
The alternator belt needs to be pretty tight. It only squeals at start-up because of the momentary load of the alternator. Mine did the same thing until I tightened them up more.
Old 03-10-2005, 07:04 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
do not over tighten the P/S belt or you will destroy the pump tho only belt that needs to be real tight is the alternator belt
Old 03-10-2005, 10:01 PM
Great information!!!!!!!!! I will be sure to loosen up the P/S belt. It may be a little too tight. I never thought about the load on the alt. @ start up. Thanks again for the info. It's PRICELESS!!!!!!!!
Old 03-11-2005, 06:12 AM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
You can ususally verify that the offending belt is for the altenator by watching the voltmeter on the instrument panel. If it seems low and then suddenly jumps up to its normal as the squealing stops---> alternator belt. I wouldn't think the other two would cause any squealing during start up since generally there isn't any load on the AC comp or P/S pump.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 08-20-2005, 09:47 AM
oak13 oak13 is offline
How do you tighten the belt
I have the 98 rodeo and I can't figure out how to tighten the tensioner pulley to make the belt tighter.
Old 08-22-2005, 08:50 AM
I don't think that you can with this type, it is spring loaded. The ones described above are the old type that you had to manually tighten. Ours has a spring tensioner, which the only way to tighten is to replace the tensioner, which could get weak over time.
Old 08-22-2005, 07:57 PM
Thanks for the info, I was going crazy trying to figure out how to tighten it. These forums are great!
