Originally Posted by jhaas1
anyone figure this out? i've got the same problem.....perfect 1st 2nd and reverse shifts great 2nd to 3rd nothing ......neutral.... must be something to it before a swap out
Turned out that the 3rd/4th gear clutch pack was burned up...which apparently is a common and weak link in this tranny. I wound up having to have ours rebuilt. Got it done for about $650 plus a friend who did the R&R for $150. NOTE: When you rebuild this or many others out there with the 3rd/4th O.D. clutch pack.....make sure you have the rebuilder put in a heavy duty/commercial clutch pack. Do not use the standard one. This makes all the difference in the world and only costs an extra $30-$50. Also do NOT tow in overdrive and make sure you have an external aftermarket trans cooler installed. Good Luck !!!
ps Also we found 2 other "junk yard" trannies with low miles ...but turned out to be the same problem. I would NOT recommend a swap out....you'll likely wind up with the same prob again in short order...unless there is proof it had been rebuilt. Save yourself the hassle and have yours rebuilt. Just a suggestion based on our prob and research.
