Spark Plugs for Jimmy
Can anyone say what are the best Spark Plugs to use on a 96 Jimmy? I am trying to figure out whether copper, platinum....What would my engine (4.3 6cyl Vortec ) work best with??
Thanks!!!!! |
Re: Spark Plugs for Jimmy
Use the AC platinum..It is what works best with your vehicle..Also if you need to change the spark plug wires I would highly recommend you use the AC Delco wires..They may be a little expensive.But trust me the expense is worth it..
The AC plug are very good, but you will dig into your pocket,
I just ck for my 96 an was $6.50 each. The adv of the AC is the mileage = 100 th mile plugs. I went with the reg ac plug for $1.95. |
For got to tell you the gap on plugs AC PLAT=.65. Also wonted to tell you how much fun you will have on #3cly.hence the Steeing rod. Gud look . |
Re: Re: Spark Plugs for Jimmy
The AC DELCO plats are the best for your engine. My owners manual says .045, but most people have had good luck setting them at .060.
Don't set them at .065. Don't use the reg AC Delco plugs in 1996+. Never use Bosch in a GM engine. They will foul and cause it to run rough. |
Re: Re: Re: Spark Plugs for Jimmy
Ok first, I my have been wrong on the plug gap ..60 is right I called and asked dealer.
And why not use the reg plugs, Is it going to hurt the eng? |
I think I rather pay more and go with the platinums instead of the Reg Plugs. I think that is what the manufuacturer specifies for my truck in particular, platinum.
If you want them cheap, get them off of ebay.
1995 Factory Blazer Service Manual for sale, PM if interested. |
i have a 98 jimmy and plan on changing the spark plugs... are platinum or copper better for mine?
All 96+ should use AC Delco Platinums.
Yep xokayxo, the AC Delco Platinums are the best for your truck!
Well, guess what you all...I went ahead and installed the AC Delcos on my truck instead of the Bosch +2 Platinums I had on it previously, and it has not been as good as I expected them. My Jimmy' RPMs shoot up past 1500 when I turn the ignition every morning, and there is this Knock and ping sound whenever I accelerate or when going uphill.
This never happened with the Bosh I had on it. Could the new AC Delcos be the problem? |
