| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
Can someone please offer assistance. I have a 2005 Nissan Maxima (fully loaded). I dont have remotes for the car.
However, I purchased new remotes off Ebay for the car. Can someone provide me programming instructions , so I can program these brand new remotes to my car. Thank You very much. |
Re: Keyless Remote programming for 2005 Nisan MAxima
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when: -remote controller or multi-remote control unit LCU05 is replaced. -an additional remote controller is activated. ID Code Entry Procedure To enter the ID code, follow this procedure. Entering "Setting mode": (1) Close and lock all doors. (2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated. ID code entry: (3) Turn ignition key to "ACC" position. (4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.) Additional ID code entry (5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock knob. (6) Push lock button on the additional new remote controller once. (7) This ID code entry enable state and setting mode remain until the driver's door is opened. NOTE If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller. If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored. Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored. Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode. |
