Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 03-08-2005, 04:13 AM
Mr.Griz Mr.Griz is offline
Diff Additive?
I have a 91 sierra and am changing the diff fluids, i will be putting in a synthetic fluid, my question is do i need a special additive as well?
Thanks
Old 03-08-2005, 06:03 AM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Re: Diff Additive?
I was advised not to put any additive into my diff, however, I did use Mobil 1 synthetic gear lube 75-90. 12,000 miles, no problems yet.
Old 03-08-2005, 10:17 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Diff Additive?
unless you have limited slip with a clutch pack there is no reason to put any aditive in. usually only fords need an aditive, the only reason you should use an aditive is if the clutches chatter while turning.
Old 03-12-2005, 06:19 AM
blabhern's Avatar
blabhern blabhern is offline
Send a message via AIM to blabhern
Re: Diff Additive?
check your RPO codes in the glove box. If you see a G80, then your truck has a limited slip rear end. it needs the additive. Autozone sells it.
