Old 03-08-2005, 12:31 AM
hammer906 hammer906 is offline
1994 GMC Sierra K3500 pick up truck
Need to adjust timing on newly rebuilt motor, and was told there's a wire called a 'breakoff' wire that goes from the distributor to a terminal block on the firewall or inner kick panel, and must be separated before timing light is used. Cannot find wire. Please help. Jeff
Old 03-08-2005, 08:02 AM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Re: 1994 GMC Sierra K3500 pick up truck
You posted in the wrong forum. Should be somewhere near the distributor, open connector. I believe it needs to be shorted to ground, so that the computer will not make timing adjustments while you are setting base timing. I can't tell you for sure however.
Old 03-15-2005, 08:48 PM
amac209 amac209 is offline
Send a message via MSN to amac209
on a 94 that wire is in the area down under the glovebox. it's a tan& blackwire. your timing should be set to 0 with this wire unhooked.
