Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 03-07-2005, 10:01 PM
darkbsc darkbsc is offline
307 wanna replace the 2 barrel with a 4
can it be done and is it practical? its a 1968 chevelle
Old 03-08-2005, 09:36 AM
hsas_69 hsas_69 is offline
Send a message via Yahoo to hsas_69
Re: 307 wanna replace the 2 barrel with a 4
it can be done and it is very practical. You need to find a 4 barrel manifold to fit the block, perferablly edlebrock, and a 4 barrel carb, also edelbrock i would perfer a 650 cfm. and you need the intake gaskets. make sure not to get a high rise intake or you will have clearence issues with your hood.
Old 03-08-2005, 07:08 PM
molhannah molhannah is offline
If you want an original cast iron intake, I have a couple. I use to live in Torrance, bet it has changed over the years. We use to cruise PCH and Hawtrone Blvd.
Old 03-21-2005, 06:50 PM
chevyboyy chevyboyy is offline
yea changing to a 4 barell carb is very easy just make sure when you get the intake manifold and carb that the bolt patterns match
Old 03-23-2005, 10:15 PM
JustinHoMi JustinHoMi is offline
I've also got a 307 that I'd like to switch to 4brl. What are some good, inexpensive intakes and carbs? I'm not sure how much it's worth spending.
Also, these 307's have the oil cap on the intake. Most intakes that I've seen have no oil cap (since it's usually on the valve cover). Do we need to relocate the oil cap to the valve cover?
Justin
Old 03-24-2005, 09:55 AM
I sold Darkbsc an original cast iron for $20.00 and $15.00 to ship it to Cal. You can still find them in some wrecking yards. You can also find used aluminum intakes on ebay, and the early ones have the oil fill hole for the tube. If you purchase one without the filler hole you will have to change valve covers also.
