Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 03-07-2005, 09:23 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Talking How many miles do you have on your Isuzu?
I thought I would start this trend to watch our members Rodeo's rack up the miles over the years.
Here is the format to use:
Year:
Engine:
Mileage:
Any major problems:
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-08-2005, 06:43 PM
awer25 awer25 is offline
1998 (Trooper)
3.5 V6
151,659
No probs yet! (it was bought at 133k)
Old 03-09-2005, 02:28 PM
95trooper 95trooper is offline
Re: How many miles do you have your Isuzu?
Year: 1995 (Trooper)
Engine: 3.2 V6
Mileage: 108,000
Any major problems: Just recently had problems with power loss, but I had the catalytic converter replaced and all is well (gas mileage went back up to normal).
Old 03-10-2005, 07:28 AM
herkfe27 herkfe27 is offline
2000 Trooper
3.5L
68,250
none
Old 03-10-2005, 08:24 AM
snap11 snap11 is offline
Originally Posted by herkfe27
2000 Trooper
3.5L
68,250
none
1993 trooper with 165,400 on it .it has the 3.2 sohc.still runs strong.
Old 03-13-2005, 05:08 PM
PeteCal PeteCal is offline
1998 Trooper
3.5 L
Intake gasket blew under warrenty
Engine #1 bearing went at 63K Needed new short block
Had to rebuild the EGR at 70K
Muffler at 102K
Transmission fluid line to radiator rusted out at 112K. Patched with rubber hose.
Had to rebuild the EGR again at 113K
Power Steering line rusted out at 114K. Replaced the line for $75.
Old 03-14-2005, 04:32 PM
BOUTO29355 BOUTO29355 is offline
Year: 2001 Trooper LS
Engine:3.5 liter 6 cylinder
Mileage:86,000
Any major problems: Great vehicle. No problems until recently. Check engine light keeps coming on even after I disconnect the battery cable. Reduced power light comes on immediately after the check engine light comes on. Reducing power drastically. P1125 code. I have an open posting asking for help on this.
Old 03-31-2005, 05:17 PM
[iV]Kermit [iV]Kermit is offline
1991
2.8l 5-speed
159k
Needs transmission repair, clutch, manifold gasket and some other stuff. A local college is going to work on it next year for me I just pay for parts.
Old 04-30-2005, 11:31 AM
blwn98LS blwn98LS is offline
Send a message via AIM to blwn98LS
1997 Trooper LS
130,000 miles
3.2 L, 4wd
this truck was great right up to the time a lumber truck backed into it and totalled it. (my wife is recovering, but the truck is sably missed)
1998 trooper ls
117,000 miles.
3.5 L, TOD 4wd
bought it used 2 years ago
mechanic tells me it has a bad cylinder and the oul is dumping into it. says it is only a matter of time before it blows and I should decide wrther to shell out thousands to fix it or trade it in. Also, TOD check light just started flashing and one of the auto locking hubs makes a grinding noise occasionally when engaged. (not fond of the TOD by the way). Love the truck and would love to have it fixed but I must think hard about it.
Old 05-19-2005, 08:38 PM
werks2much werks2much is offline
2001 Trooper
3.5L V6
41,000 miles
Old 05-20-2005, 12:36 AM
tinytrixie's Avatar
tinytrixie tinytrixie is offline
Trooper
year: 1999
3.5L
122K
Repairs: Starter, all other just maintenace
uses from 1 to 1-1/2 qt oil between 3K changes
Old 06-12-2005, 05:13 PM
88Goldtrooper 88Goldtrooper is offline
1988 trooper
218000 miles
Owned since brand new with 12 miles
The head was cracked and replaced under warranty.
Been hit by a deer, two cars and almost totaled once.
Old 06-14-2005, 12:47 PM
bjayjohnson bjayjohnson is offline
Year: 2001 Isuzu Trooper
Engine: 3.5 L
Mileage: 58,000
Any Major Problems: Intake gasket failed at about 32,000 miles while under warranty. Discovered incorrect Champion spark plugs were installed in my vehicle about 16,000 miles later.
Comments: Used an engine cleaner after two problems were fixed. Installed synthetic oil. Use an fuel injector cleaner every tankful. Engine now operates very smoothly. Trooper also consistently achieves about 22-24 mpg. I love this SUV!
Old 06-19-2005, 08:38 PM
jmarble jmarble is offline
1993 Isuzu Trooper info
Year: 1993
Engine: 3.2 L SOHC
Mileage:180,005 miles
Any major problems:
1. Replaced fuel pump 176k
2. Replaced pinion rear bearing, pinion front bearing, and bearing on axle
at 177k
3. Replaced valve cover gasket, spark plug seals, and 2 fuel injectors at 152k
Old 06-27-2005, 11:58 AM
1flyboy 1flyboy is offline
Smile Trooper Miles
Year: 1989
Type: Trooper
Miles: 245,000
The only problems so far have been air conditioning quit at 210,000 with some kind of short(Keeps blowing fuses). And now today I'm replacing the fuel filter and pump along with the relay, it won't start. This is the first time it's not started since I've had it.
