Old 03-07-2005, 09:06 PM
MacSanderson MacSanderson is offline
2000 nissan frontier xe differential
I just got my desert runner and was told that it has a locking rearend. Well the snow came hard and I spun one tire with an ocasional transfer.
Does the truck have a locking or limited rearend and should it work better than this? Is it mechanical or electric? Does it work off ABS sensors? Can I override and lock it on and whats involved?
Additional information: 2000 nissan frontier xe Dessert runner, 5 speed manual trans and ABS. v6
Old 03-07-2005, 10:21 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 2000 nissan frontier xe differential
I saw a toyota that had a switch to lock the diff on the dash. nissan and toyota are the same, so look there.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-08-2005, 07:29 PM
Re: Re: 2000 nissan frontier xe differential
Thanks for the info I'll do that
