Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-07-2005, 08:27 PM
ricebrnr13 ricebrnr13 is offline
evo injectors
what size are evo8 injectors? i was told they are 550. i'm currently building a 2g talon and need bigger injectors. i've been told these will work but i haven'y heard any thing about it. i have a evo3 turbo comp cams, 3'' exhaust, afc and so other parts. i'm pretty sure that 550's would be alright.
Old 03-07-2005, 10:05 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: evo injectors
560cc. I'm in the market for some, too.
Old 03-08-2005, 06:04 PM
joemathews's Avatar
joemathews joemathews is offline
Re: evo injectors
560cc Evo8 injectors=the cooolest :
Mine have worked beautifully with the Evo16g, running 17 psi on the stock pump with good timing.
1996 Eagle Talon
Old 03-09-2005, 09:01 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: evo injectors
MAke sure that stock pump is rewired, or those injectors end up having way more capacity than it. I get ~40 lbs/min for both, rewired. Not a bad match. This assumes 2g, the 1g pump is a toilet.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-09-2005, 01:23 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Re: evo injectors
What are the price ranger for evo 8 injectors. What other evo injectors work. I can check out the japanese auction to see if i can get some cheap.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 03-09-2005, 02:08 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Re: evo injectors
Dam ragin if you find some for a good pirce on the japanese market hook it up!
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 03-09-2005, 07:04 PM
Killa_DSM's Avatar
Re: evo injectors
I have a supra intercooler (got for 2000yen= about $20) on the way and I may bid on a evoI 16g since i got gypped out of the 14b. The evo8 injectors are going for 12,500 yen. Which I think is around $120, is that expensive or cheap?
Old 03-09-2005, 10:31 PM
Re: evo injectors
Holy shit thats cheap pretty cheap....are you buying this off the japanese ebay listings?
My Car
Old 03-09-2005, 11:14 PM
Killa_DSM's Avatar
Re: evo injectors
I dont want to take over this thread, so if theres any questions just pm me. Sorry for the change in topic!
Old 03-10-2005, 12:24 AM
JoeWagon's Avatar
Banned
Re: evo injectors
You can buy them from evolutionm forums for $150. That's where I'm going to get mine.
Old 03-10-2005, 03:55 AM
joemathews's Avatar
Re: evo injectors
Yeah you can find them on EvolutionM.net classifieds for right around $150 most of the time.
Kevin, was that 40 lbs./min. calculated at 100% duty cycle? Because damn, on 40 lbs./min. on a stock pump, even rewired, surprises the shit out of me.
1996 Eagle Talon
Old 03-10-2005, 07:56 AM
AF - Advisor
Re: evo injectors
To which are you refering, the pump or the injectors? The reference to IDC makes me think injectors, but stock pump makes me think pump In any case, the injector value given is wide open, so 100% IDC. The pump is assumed rewired, fuel SG of .76, and AFR of 11:1. I just realized my error though. Its good for 40 lbs at 15 psi, which is going to be pretty much impossible on a 2 liter Its good for 27 lbs at 30 psi, so a rough estimation of in between those points is ~34 lbs/min at 22 psi. Its more than enough for a 14b, and close with 16Gs, not enough for an evo perhaps. But then again these are pump gas numbers. Who would be going over 30 poudns/min on pump, or 20 psi? Not many poeple, but be aware that its risky on the stock pump. Let look at race gas. The numbers become 43 lbs and 29 pounds, at 15 and 30 psi, respectively. Not much of a gain I guess. At any rate, I put together that spreadsheet on my site so people can play with these numbers themselves and make educated decisions. Its up to each person to decide how far he wants to push things. For a EVO16g and up I would not run the stock pump based on these numbers. But its damn close, and much better still than people give it credit for. The 1g pump however is a toilet and should get replced much sooner, mathematically it doesnt even support enough airflow to max out a 14b at 25 psi.
Kevin Jewer
