Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-07-2005, 08:24 PM
aitch aitch is offline
egr valve
My 99 rodeo 3.2 keeps on cutting out in city driving. It has 164k miles and never been in the shop. Apart from the usual maintenance, any thoughts. I have been noticing some threads on egr valves and oxygen sensors but not really familiar with either.
Old 03-07-2005, 08:55 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: egr valve
sounds like you have the classic IMG (intake manafold gasket problem) There are probably about 5 new people here a week with this problem.
Read through the FAQ's for more maintance questions and answers.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-07-2005, 09:02 PM
hissing noise
Thanks for the previous response Ryan. I do not know if this problem is related to my idling issue but whnever I step on th gas pedal there is a hissing(whooshing) noise. I thought it maybe a vacuum problem but I have been told you would here that noise whenever you let off the gas. Confused again.
Will
Old 03-07-2005, 09:11 PM
Isuzu Guy
Re: egr valve
Right from the FAQ's
Do you have a Rough idle, check engine light on, or air leak noise from under the hood. The Intake gasket breaking may be the cause on the 98 and newer v/6 Trooper and Rodeo.
-Ryan
Isuzu Moderator
Car Show Tips
Old 03-07-2005, 09:52 PM
Realized after post was sent. Are there any diagrams available or instructions?
Will
Old 03-07-2005, 09:56 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
Re: egr valve
I paid to have my IMG fixed($290-ish), but if you are comfortable working under the hood I do not believe it is that difficult. I almost wish mine happened when it was warmer out because I may have attempted it.
Also it is a good idea to clean the EGR as well.
Marc
Old 03-07-2005, 10:14 PM
Isuzu Guy
Re: egr valve
How to:
http://isuzufaq.ibctech.ca/#faq5
-Ryan
Isuzu Moderator
Car Show Tips
Old 03-07-2005, 10:35 PM
SOLSTER SOLSTER is offline
aitch, if you've gotten 160K plus on the same rig I've got, and I only have 60K, and I've looked after mine pretty well, I hope I can say I'm set (nock on wood)! Have you had any oil consumption issues? These engines are known (but not in every case) to need a large dose of vigilance on watching the oil stick, like every fill up. If you're not aware of the issue, do a search on "oil consumption" and it will be evident.
best of luck
SOLSTER
1999 Isuzu Rodeo S 3.2L, 4x4, Auto, Great Truck!
2007 Pontiac Solstice GXP, Aggressive Red
Old 03-08-2005, 09:44 PM
Hey Solster, probably going through about 1qt per k. I also use mobil1 synthetic. This might sound unusual but I have not even changed the front brakes yet although it feels as if the rotors are warping slightly. Guess this is a job for next weekend. Just turned 165k today.
Aitch
