Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-07-2005, 07:20 PM
pb31 pb31 is offline
another IAC question
94 LX Tbird. For the past month and a half, I've noticed that my idling after startup has been screwy. The rpm's will drop below 500 when i'm backing out of my driveway and when I come to a complete stop at a stop sign or traffic light. This droppage will only last a second or two and then it's back to the normal rpm range. After like 10 mins of driving the car is fine at traffic stops.
After two weeks of this, I bought a can of CRC Air-Intake Cleaner and sprayed the IAC out. The rough idle practically went away. However, a week later the idle troubles returned. This past weekend I put a new IAC valve on and I'm still having the same problems. The IAC valve was purchased at a Ford dealer. Is there a time period that I must wait for my car's computer to adjust to the new part? Second, if the IAC isn't the problem, then what should I look at next?
Old 03-08-2005, 08:54 AM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: another IAC question
Did you disconnect the batterey for a while?
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 03-08-2005, 02:22 PM
slowthunderbird slowthunderbird is offline
Wink Rough Idle??
Have You Checked your MAFS Or Clean Your Throttle Body...Oh And Make Sure You Check All Of Your Vacuum Lines...They Control Some Pretty Stupid Stuff....
Old 03-08-2005, 06:19 PM
iac
I did not disconnect the battery after the switch.
About two months ago, I removed my MAF (very carefully) and the bulb appeared to be clean. So I didn't do anything to it, plus I have read that the MAF is easy to break. I have not cleaned the throttle body either.
