Old 03-07-2005, 05:07 PM
awdpower awdpower is offline
Send a message via ICQ to awdpower Send a message via AIM to awdpower Send a message via Yahoo to awdpower
I Got A Problem
I had just put a battery in my car and the other day my car did not want to turn on any ideas wat it could be??? Alternator, battery, fuse, or what???
Old 03-07-2005, 05:48 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
check the batt terminals for a good connection and its most of the time a ground.if that does not work then check the fuses but its some times something simple over looked.
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 03-07-2005, 05:52 PM
Re: I Got A Problem
So you say it might be the ground???
Old 03-07-2005, 05:56 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: I Got A Problem
It could be, check all of your connections for any sign of corrosion (battery to starter, battery to ground, etc). If you see anything that even remotely looks suspicious...clean it. The best thing for that (if you don't have terminal cleaner) is a can of coke or pepsi. Just dip the terminals in and viola! Also, like 1g suggested, check all of your fuses.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-07-2005, 06:31 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: I Got A Problem
Use pepsi...don't waste something as amazing as coke
"You can have everything in life you want if you will just help enough other people get what they want."
Old 03-07-2005, 06:36 PM
Re: Re: I Got A Problem
Well I changed the terminals on the battery the other day and the ground cable was already old and it was hanged on to a little piece so I took it off and just put battery cables. I put like three battery cables but using them as ground and there only 8 gauge, u think that might be the problem.
Old 03-07-2005, 06:40 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: I Got A Problem
Did you test the battery? What does 'not want to start' mean? Did it crank? Not crank at all? Weak? If you have a new battery, the alternator doesn't matter.. the car should start and run for quite a while on just battery power. Also, the thread topic is quite vague.
