Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-07-2005, 04:01 PM
Dasbogie Dasbogie is offline
Wink 01 Ranger check engine/EGR
Hey, I have a 2001 Ranger Edge, v6 4.0l 4x4 automatic. Recently the check engine light popped on. I took it to autozone and they told me the code they pulled was EGR valve, excessive flow. I replaced the egr and cleaned around the connections to remove carbon deposits. Ran my truck for a day or 2. The light stayed on so I disconnected the battery for 10-15 minutes or so. I hooked it back up and the light was off. That lasted about a day. Now the check engine light is back on. Took it back to Autozone and the same code came up. Any ideas to check. I was going to buy a haynes manual but the ranger only goes to 2000. Is there that much difference from 2000 to 2001? Any help would be greatly appreciated. Thanks
Spencer
Old 03-07-2005, 04:30 PM
splashiod's Avatar
splashiod splashiod is offline
many will confirm, it's DPFE sensor. about 2x3 inch rectangle box on intake with 2 hoses & electrical connection. follow small hose from EGR valve & you'll find it. about 60-70 bucks at dealer. Good Luck
Old 03-10-2005, 01:14 AM
Re: 01 Ranger check engine/EGR
I replaced the dpfe sensor today. That was about $30 at local dealership. The light is still on though. Gonna disconnect the battery to clear it and hope it is fixed.
Old 07-06-2005, 12:54 PM
iprogcnc iprogcnc is offline
Cool
I also own a 01 Ranger with a 4.0 sohc v6. I have been battling with an EGR problem for a month now. I have replaced the EGR valve and the Pressure feedback sensor and am going to replace that $30. sensor
that you have just replaced DP something! Let me know what you find out. I went on an online auto diagnostic pay site last night and it lists 10 + possibilitys that can cause this. I have check codes 402 403 and 1400. They also say to check all the vacuum lines and I found a 90 deg. hose on top of the manifold with a crack in it and replaced it. Also the metal tube that runs up to the EGR valve can clog up. Mine wasn't though! Hey good luck to you!
Old 07-07-2005, 01:17 PM
Thumbs up
That DPFE sensor that splashoid spoke about seems to have done the trick for me! If he reads this all I can say is many thanks.
I have a new problem to address though my air bag light has come on and stayed on do you have any info on this!
Old 07-07-2005, 02:44 PM
splashiod's Avatar
Your Welcome! I had same problem & found out it's very common. Never had airbag light stay on, go to www.rangerpowersports.com & do search for "airbag light". I'm sure you'll find an answer there. Good Luck!!
