Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-07-2005, 12:45 PM
jrm0915 jrm0915 is offline
Hot start 96, Explorer
To keep it short, cleaned the MAF sensor, did a tune-up on normal components, and I still get a code PO401, having to do with the EGR valve. Replaced the EGR valve, and after only a couple of days, the code light is back on, same code, and still showing a rough hot start/idle. No other codes. Anyone have any ideas?
Old 03-19-2005, 02:31 AM
rginter rginter is offline
Did you check to make sure the intake wasn't plugged up while you had the EGR valve off? You may need to clean it out.
