Old 03-07-2005, 09:51 AM
jl1234567890 jl1234567890 is offline
Question subs in standard s-10?
i have a standard size 88 s-10 with very little room behind the seats. i want to put subs possibly 2 10inch or maybe even 2 12inch. i dont think the 12 will even be close to fitting. i have faith that i can squeeze 2 10s in SOMEHOW lol. and recomondations? does any1 know a specific brand or sub-box combo that will fit behind theses seats? or maybe i should buy subs and make my own box? i would guess theres about 7-8 inches at the floor behind the seats and as it goes up the room narrows. a standard box will not fit but the subs will. any suggestions?
Old 03-07-2005, 10:32 AM
kenyonja2007's Avatar
kenyonja2007 kenyonja2007 is offline
Send a message via AIM to kenyonja2007
I've got a '94 regular cab, and I'm assuming I have about the same amount of room as you. I have a 10 inch behind my seat. I couldn't find a sub box that would fit that was under like 100 bucks, so I built my own. I have enough room to fit 2 10's but I don't think I would have enough for 2 12's. Even with my one 10 it is just barely enough volume to be a sealed enclosure. Just took my time and made one out of plywood and it works awesome. Also fit my amplifier right next to it. I'll take a picture a little later for ya.
1994 Chevrolet S10
2.2L, 2WD, Auto, Long Bed, more here
Brakes are a good thing
Old 03-07-2005, 09:06 PM
xtrememeasures10 xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Re: subs in standard s-10?
Alot of ppl ask about this. Its easy. i have a 97 standard cab with two audiobahn 10in subs. and an amp rack holding my audiobahn amp inbetween them. 12s require a little box more space to hit to there full potential. i opted to go w/ 10s. Make your boxes out of 3/4in MDF. NOT plywood. I had to relocate my jack so i could fit them. ill take a picture tomorrow and upload it.
Old 03-07-2005, 10:03 PM
Just curious, why shouldn't you make sub boxes out of plywood? I used 3/8ths ply and it seems plenty rigid, if that is the problem. Not sure, I'm no expert.
1994 Chevrolet S10
Old 03-07-2005, 10:10 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Personally, I wouldn't even use MDF. In my shop, I use HDF because it is extremely hard. This hardness helps keep it rigid so it doesn't flex with the music.
As far as the space and sub concern, I've gotten many 12" woofers in reg. cab trucks. The trick is to pick the right woofer for what you want. Normally I choose sealed boxes because they are smaller than ported. Even so, sometimes ported is the choice.
I love Directed Audio subs just for this reason. I built a box for a 12" CompX sub that was only .3 cu/ft box!!!! I reverse mounted it and it pounded!!! Many other brands like Audiobahn require boxes at least 3x's that size. Obviously you'll need something custom made here. No prefab box is going to work for you.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 03-08-2005, 12:45 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
do a search on google and on ebay.
There are premade s10 subwoofer boxes.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-08-2005, 05:20 AM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Plywood is pourous so to speak and not rigid.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 03-08-2005, 09:20 AM
thanks alot everybody i heard what i needed.. the pics would b nice to see too. i think im just going to build my own sub box for 2 10s audiobahns off ebay i found a nice pair on there.
Old 03-08-2005, 05:47 PM
This is the setup behind my seat. Only a cheap RF 10 inch and a 100watt RF amp but it is plenty for the small cab space in the truck. Crude, but works very well.
1994 Chevrolet S10
Old 03-08-2005, 05:48 PM
whoa, didnt mean to make it that big
1994 Chevrolet S10
Old 03-08-2005, 08:43 PM
Theres a pic of my setup. My subs are temporary. My first set of audiobahns were mess up in my wreck. So i have a set that was given 2 my from my friend. ill have audiobahns w/ grilles soon. As i said you have 2 cut out your jack inorder to have enough room. i have a hard top on my bed so that was no problem throwing my jack in there other wize theres room under your seat or under your hood in a bag to keep it dry. well have fun w/ it.
Old 03-08-2005, 09:00 PM
Re: Re: subs in standard s-10?
oooh about plywood. no offence or anything dude. MDF is much more dense. Medium density fiberwood is in my opinion the best for the money. HDF High density fiberwood im assuming. never used it for a box. couldnt give you an opinion on that. Make sure you drill your holes w/ MDF it will crack very easily if you dont. and i reccomend liquid nails or a strong wood glue between pieces. wont ever have to mess with it again. OOH and if your wandering why i didnt carpet mine. 1/8th of an inch is how much closer it would be to my seat. which equaled moving it one more notch. foreward. Ill puddy the screw holes and paint it one day lol. I used sylicone cauk on the inside seams to seal it.
Old 03-08-2005, 09:18 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
xtream, very nice setup, but you can carpet it, just dont carpet the backside... and if you still think the carpet is to thick, go to walmart or joans, and get yourselfe some fabric instead of carpeting
Old 03-08-2005, 09:46 PM
Ok, sounds like plywood is not the way to go, but it sounds fine to me and is rigid enough if you use thick enough stuff I suppose.
1994 Chevrolet S10
Old 03-08-2005, 09:48 PM
plywood is a no no, it can crack apart, use partical board if your going to use something cheep, the glue in the pb is stronger then the wood itselfe, making it overall, stronger then a piece of plywood
