Old 03-07-2005, 08:47 AM
FutureFire FutureFire is offline
Thumbs down 94 Blazer- Bog Down and stall when cold
My 94 Blazer s10 is a v6 Vortec 4x4~
Issue:
When the engine is cold there is a vibration coming from firewall top area of engine. The engine will periodically bog down/ then the CPU will dump fuel into the engine and the RPM's go up for awhile then it bogs down again. Sometimes it will stall before cpu can dump fuel on it, the issue is getting worse and worse with stalls becoming more frequent. I can avoid stall by hitting accelarator. Once all the way warm and driven on normal honey do errands for the day it runs perfectly, vibration even gone. No idiot lights yet;
Current troubleshooting done
I was almost certain that the vibration was cap and rotor. I could feel vibaration strongest when I put hand on cap while idle. Replaced cap and rotor to no avail. Will be replacing wires and plugs this week. However I am by no means a rich man and diagnosing this problem by replacing ignition system a piece at a time then moving onto fuel delivery and air control systems will break a fool.
Old 03-07-2005, 02:14 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 94 Blazer- Bog Down and stall when cold
Check your CPI injector by removing the top Vortec cover plate, remove the round IMTV valve under it noting its orientation for reinstallation and then take a flashlight and shine it down into the hole and look for pools of fuel, the strong smell of gas and washed spots that will be a golden color.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-11-2005, 12:49 PM
Re: Re: 94 Blazer- Bog Down and stall when cold
Removed IMTV valve and checked CPI injector for leaks/additional wear and all looked normal. No strong smell of gas. Going to hook up OBD1 Scanner and see if we can see anything with the sensors; We also are going to check fuel pressure; Still looking for suggestions.
Old 03-11-2005, 02:16 PM
BlazerLT's Avatar
AF -Advisor
Was there any golden washed spots>
Pools of fuel?
Old 03-11-2005, 04:06 PM
No.
Old 03-11-2005, 06:43 PM
BlazerLT's Avatar
AF -Advisor
Originally Posted by FutureFire
No.
So it was perfectly black down there with no discoloration at all?
Old 03-11-2005, 07:17 PM
It was almost perfectly black, there were no clean spots or discoloration. There did not appear to be any leaks at all. Any other ideas?
Old 03-11-2005, 07:20 PM
BlazerLT's Avatar
AF -Advisor
Check fuel pressure.
Old 03-12-2005, 02:22 AM
It was a bad distributor. I got a new one and put it in. Do you have any idea what the timing should be set to, and if there in any wiring that must be jumped or disconected while setting the timing? Or where the timing mark is? I am too tired for this. Thanks for your help.
Old 03-12-2005, 03:25 AM
BlazerLT's Avatar
AF -Advisor
Remove the timing wire from the PCM, set to zero with a timing gun, reconnect wire.
Old 03-12-2005, 12:49 PM
Do you know where the timing wire is that I must disconect?
Old 03-12-2005, 11:12 PM
BlazerLT's Avatar
AF -Advisor
under the glove box.
