Old 03-07-2005, 08:10 AM
max5150 max5150 is offline
aghh DEXICOOL..I hate it!
Ok so anyone else have a dexicool problem?\
I have replaced my heater core and flushed out the system the best way i could. Brown yucky sludge came out. I run the engine and still only one of the heater core hoses is hot the other cold> is it plugged up again??>? I had heat for about ten minutes then it stopped again.
Maybe the water pump is bad from the dexicool??? It doesn't overheat at all even though only one side of the heater core hoses is hot, thought maybe the coolent has to get to the other side of the engine to cool it down and it went through that.
what do you guys think?
Old 03-07-2005, 02:17 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: aghh DEXICOOL..I hate it!
Reverse flush the heater core.
Flushed the best you could? What does that mean?
Replace the rad cap with anything other than an AC delco.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-07-2005, 09:29 PM
J-Ri's Avatar
J-Ri J-Ri is offline
If the truck's not covered under warantee anymore, just flush the dexcool.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-07-2005, 10:12 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: aghh DEXICOOL..I hate it!
I don't think he flushed it properly in the first place.
