Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 03-07-2005, 07:40 AM
Dana G. Dana G. is offline
Here is a weird one!
Last week i posted (missing and backfiring), now i have a new one! I replaced the plug wires and plugs and it seemed to help for a day or so but now it is doing it again! All of that made my check engine light come on so i unhooked the battery to reset it and it went off, while the check engine light was off, it would backfire and miss and bog down, but the light came back on, and when it did, it quit all of that and it runs fine while the light is on!!! I cant figure it out, i need help!!!
Old 03-07-2005, 03:18 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
Check the fuel pressure. My jeep would run good off and on, but eventually the fuel pump failed. I have a 92 4.0l high output. I know there was also a problem with the distributors on some of these Jeeps, your might be failing.
Old 11-10-2005, 11:06 PM
jon_renegade0 jon_renegade0 is offline
Re: Here is a weird one!
i don't know what engine or year you are, my my 90 yj did the same thing. i have a 2.5L, i had to replace the intake/exhaust gasket
Old 11-15-2005, 10:01 AM
Get the code checked @ autozone, they don't charge. I'd bet money that it's the CPS.
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 02-18-2006, 10:07 PM
sb5551 sb5551 is offline
I dont know if you have figured out your problem yet, but what happens when a sensor fails it shows a code and the computer automatically runs the car in open loop (it puts a fake sensor reading so the car is drivable). When you reset the computer it had to run on a bad sensor then put the code on again.
