Old 03-07-2005, 07:01 AM
Ducaire Ducaire is offline
Does anyone else have this problem?
Whenever it's cold, and my truck hasn't warmed up yet, my S10 doesn't want to change into the highest gear. I have to drive about 45 mph. until it finally shifts into 4th. (It's an automatic). Does anyone know what causes this?
Old 03-07-2005, 02:37 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Does anyone else have this problem?
Are you talking about the torque converter lockup? It feels like an additional shift on most cars. It does that so it reaches optimal operating temperature quicker. See if the RPM picks up when you shift into drive.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-07-2005, 09:36 PM
I didn't know if it was supposed to stay in lower gear like that or if I had a problem. Now I know that I don't. I've also noticed that additional shift in there; even in 2nd or 3rd gear, when the temperature reaches a certain point, I can hear what sounds like it shifting into a slightly higher gear.
Old 03-07-2005, 11:01 PM
OverBoardProject OverBoardProject is offline
Banned
I wish that every problem was as easily solved as yours!
Old 03-08-2005, 12:41 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
This is normal, it won't lock in until the engine is in closed loop.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-08-2005, 07:00 AM
Re: Re: Does anyone else have this problem?
So do I. This is probably the easiest solved problem I'll ever have.
