Old 03-07-2005, 06:56 AM
Ducaire Ducaire is offline
327, 350, or 383 in S10?
(Please note that I'm going to be asking quite a few questions about this. )
Which engine would probably be best in an S10? A 327, 350, or 383? How would you compare the 3 engines with each other? (The horsepower, torqe, etc.)?
Old 03-07-2005, 12:36 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: 327, 350, or 383 in S10?
305 (not my favoret engine) or a 350, they have the most info available out there and are the easyest to do, it also makes a difference with what you have now, 2.2,2.5,2.8,3.4(f body swap) or 4.3, the 4.3 is the easyes conversion by far
Old 03-07-2005, 01:59 PM
dugie6551's Avatar
dugie6551 dugie6551 is offline
The 350 is by far the easiest and cheapest motor to get. There are not many 327 & 383 motors available compared to the 350. However, if you can pick up a 327 or 383 at a reasonable price (within your budget) then I would pick either of them over the 350. All the engines are the same physical block size, so any accessory will just bolt right up.
Originally Posted by lamehonda
AF has ruined my life. .... Thanks AF
Old 03-07-2005, 09:31 PM
Can you just order a brand new 327 or 383? (I'd probably rather have a brand new one) And if so, how much is the price?
Old 03-07-2005, 09:34 PM
all 383's that i have ever found, new or used, are stroked out
Old 03-07-2005, 11:16 PM
OverBoardProject OverBoardProject is offline
Banned
If you get a 383, or any stroker get it professionally built.
Avoid 305's
327's are all high compression, and a fast reving motor. Several peoples choice for performance.
Some 350's are great, and others are low compression pigs, so look into the years before you buy it.
Also look into 400 small blocks. They can easily be built right up and weigh the same as a 350
Some have bad blocks, but I can tell you what to look for (they overheat)
Te best performance upgrade is aftermarket alumine heads
You didn't tell us what you plan on droping this motor in. Some engines are better suited for 4x4, and some street rod applications
Old 03-08-2005, 12:40 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
400 won't fit, too big.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-08-2005, 06:58 AM
Re: Re: 327, 350, or 383 in S10?
My truck is a regular 2-wheel drive. It says S10 Tahoe (whatever that measn) on the side. My truck is an extended cab (again, it may not matter, but I just thought I'd mention it just in case.)
