Old 03-07-2005, 06:18 AM
Oakley95 Oakley95 is offline
Send a message via Yahoo to Oakley95
95 accord EX Thermo Switches????
Hello guys
I just bought a 95 accord, it has 60k on it. I have 2 small issues with it, maybe someone can help me.
#1 when should i replace timing belt?
#2 The aux. fan turns on when car is off, as it should, but the fan wont shut off , it just keeps running. So the previous owner just unplugged the relay for it, so it wont turn on at all.
#3 why is there 2 temp fan switches? 1 is at inlet of thermostat and the other is at outlet of bottom rad hose. What is purpore of these switches??
Old 03-08-2005, 12:13 AM
mpumas mpumas is offline
Re: 95 accord EX Thermo Switches????
Accords with air conditioning have two thermo switches, one for each fan. The radiator fan comes on at a lower temp then the a/c evap fan. which runs through a fan timer unit. You need to find which one is not working properly then take action. The a/c fan thermo switch goes through the timer unit so each or both may be bad if that is the one that is stuck on.
Old 08-02-2005, 10:55 AM
hazarika hazarika is offline
Re: Re: 95 accord EX Thermo Switches????
Hi,
Where are the thermo switches located? My ac clutch wont engage. Green light comes on, system is charged, if I jump the compressor it blows cold air. Is the thermo switch same as a thermostat?
Thanks.
