Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-07-2005, 12:49 AM
bumpit2001 bumpit2001 is offline
ecu testing
Is it possible to test my 97 eclipse gs ecu my self with an ohm meter or something before I send it off to get tested? Any help will be much appreciated. Thank you
Old 03-07-2005, 09:28 AM
slowgsowner slowgsowner is offline
Why what kinda problems are you having that would make you test it?
95 gs booosted ....no time yet
99 gsx stock
71 mustang 429cj...9.94
84fiero/diablo conv. in proggress
Old 03-07-2005, 10:38 AM
Ecu
Well, My friend has a 97 gs and it won't start. He's getting no power to the coil packs. We've replaced the crank sensor and we've checked the cam sensor, and the cam sensor is good. but it starts some times and runs for a few seconds and dies, the longest its ran is 20 min. So somebody told the only thing left could be the ECU and i was wondering if it would even be possible to test it and how. Thank You
Old 03-07-2005, 10:48 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: ecu testing
The only thing I could think of is to use another car. Either borrow the ECU out of another car and see if yours will start, or throw your ECU into another running car.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
