I put in a new Fuel pump, New Fuel filter, after 50 miles of running great the truck now hesitates on acceleration it feels like is not getting any gas, If I stop and turn the truck off for 5 seconds, it starts great and runs good for a little bit then goes back into the hesitation, I put in a new EGR valve, got Brand new Plugs, Even took the Throttle body apart and cleaned the hell out of it, same Problem I cleaned the MAF sensor too, I am starting to wonder if this could be the problem, I put in a new air filter and all, Any Ideas or help please!
My other car is a hyundai
Re: Running out of IDEAS
Cat converter? O2 sensors, maybe?
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Wouldnt the Cat make it run bad from the get go??
no it wouldnt...it takes a few minutes of driving for the cat to heat up...chances are its clogged
Will this throw a Cel??, also it takes less than a minute for it to start giving me the problem, also wouldnt it smell bad too??
Re: Re: Running out of IDEAS
What brand of spark plugs are you using? To be honest, knock on wood, I've never experienced a cat or O2 sensor issues on my Rodeo - with 135K, I still have my original sensors. But, I will say, the 85 Toyota that I occasionally drive does have an O2 going out on it, and it acts, on occasion like it's not getting enough air and hestitates/stumbles. Just throwing ideas out
I am using Autolites platinum, I cant afford the nipondensos right now, but The truck ran perfect b4 the Fuel pump went, any possibility of the MAF being bad??
I wonder if it could be your injectors themselves, going bad or possibly just clogged.
Have you taken that truck out on the highway, running open throttle to see what it does? Also, not sure if you've tried/thought of it, but you may have some water in your tank. Run a bottle of "HEET" (yellow bottle) on at least half a tank of gas. Can't answer your question about the Maf sensor, haven't crossed that path yet. Keep posting, I'm very curious as to what it could be.
more info about your car is needed.
1997 Honda Passport 3.2L Automatic 4x4 104,000 Miles Thanks for all the replies
Any more Ideas??
I would not suspect a fuel delivery concern if the truck starts & runs fine when cold. I would look into the MAF and also replace the autolites with NGK's. Denso's are not necessary on the 1993-1997. Has this truck ever had a cone or oiled air filter? Those foul up MAF's easily on these trucks.
G/luck Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
Good news I dropped a container of HEET(.89cents)
And runs like a champ, Thanks all.
Well problem is back
CEL codes read P1171 manufacturer control, fuel/air metering P0132 HO2S Circuit High Voltage Bank 1 Sensor 1 P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2 P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient poured more HEET and went away again. can both my O2 sensors be bad??
Yes, it's possible.
Clean the EGR, run good quality gas - like Diamond Shamrock, Shell, Texaco and put some more HEET in. See where that gets u.
