Old 03-07-2005, 12:12 AM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Jdm D15
I recently got a new engine in my car because my old oil-burner needed to rest in peace (or pieces). So I went to the shop and had them drop in a new D15...they told me that it was a JDM engine but it was basically the same one that was in the car before. The engine says "D15" on it but the DX engine is a D15B2..is the engine the same or is there some differences to it? I know that there is a D15 vtec but that's not my engine...
Old 03-07-2005, 12:58 AM
DirtyD777's Avatar
DirtyD777 DirtyD777 is offline
Send a message via MSN to DirtyD777
I have the same motor. Jdm d15b non-vtec. It is alittle better block then the b2 but nothing noticeable really.
Old 03-07-2005, 01:03 AM
travagliante's Avatar
travagliante travagliante is offline
Re: Jdm D15
Yep basically what he said. It is also STOCK mpfi, did they swap your dpfi harness on?
Re: Jdm D15
argh i mean dpfi manifold on it?
Old 03-07-2005, 01:21 AM
PhReAzE PhReAzE is offline
Send a message via MSN to PhReAzE
Re: Jdm D15
black round fouel injection thing, instead of mpfi having the rail
Old 03-07-2005, 11:24 PM
Re: Jdm D15
yes they kept DPFI on the engine..I don't think it could damage the engine?? is the jdm d15 built better?
Old 03-08-2005, 12:09 AM
Bunger's Avatar
Bunger Bunger is offline
Re: Re: Jdm D15
If there is any real difference it might be the compression is a touch higher, and the cam might be a bit more agressive, both should give you a few more HP, but should be just as reliable as the USDM part.
Old 03-08-2005, 01:31 PM
SSJSubgeta's Avatar
SSJSubgeta SSJSubgeta is offline
Send a message via AIM to SSJSubgeta
Re: Jdm D15
well theres only one diffrence from the info you provided, its a D15 non- Vtec right?, cause my motor is coming in tomorrow and its a D15 Vtec JDM long block, did they tell you if its a long block or short block?
Old 03-08-2005, 10:13 PM
Re: Re: Jdm D15
if long block means block and head, then yes it is a long block, the engine came with a head on it. non-vtec.
