somethings wrong with my 95 cavalier
Something is seriously wrong with my car. It is shimmying real bad and it pulls to the right real bad. It also makes a constant humming sound anytime i'm driving. Even if I'm only going like 5 mph. Tonight I was driving and I started to smell burnt rubber. This is the first time I've experienced this. I also notice uneven wear in the tread of the tires. I have replaced both wheel bearings and two motor mounts so I know it's not that. I'm at a loss and this car has to last me a long time because I just paid it off. Someone please help!
Re: somethings wrong with my 95 cavalier
Welcome to AF. I would jack the front end up and check for any loose bolts or maybe a damage tie rod. If your getting that much play you should be able to spot it. Since you have mentioned you replaced both wheel bearing. I am going to guess its a damaged tie rod which normally don't cause noise but would cause pulling to one side. Good luck
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
You might have a quick look at the plastic inside the tire wells, especially behind the wheels. Its quite possible some section(s) have come away from the well and is jammed in there somewhere. Also, make sure stuff connected to the brake assy is not out of place and engaging the inside of the tires. Are all your flaps in place correctly? Brake components misinstalled?
Be careful driving. This could be a serious warning of impending failure of some inportant components. Tookie |
Re: Re: somethings wrong with my 95 cavalier
car
I had a buddy of mine look at it and he believes it is the driveline or something like that. Seriously, it feels like my tire is about to fall off or something. It scares me half to death to drive it.
Re: car
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come 'Never forget Grasshopper, Not speed, smile!' |
the wearing of the tires is on the outside edge and only on the front left tire. could it possibly be the cv-halfshaft/drive shaft? i've been looking up symptoms and i forgot to mention that there's kind of a clicking sound when i turn the wheel to the right.
If it has been wrecked, reposition undercarriage. Check undercarriage bolts. Bent rim, rubbing on caliper. Check strut for rubbing.
