Go Back   Automotive Forums Car Chat > Subaru > General Discussion
Old 03-06-2005, 10:16 PM
rustyoldchevy rustyoldchevy is offline
no fire to plugs on 86 xt turbo 1.8 help
Recently purchased a 1986 Subaru XT Turbo Coupe not running, the timing belt is o.k., the distributor is in the correct location, power to the coil and voltage coming out, cap and rotor o.k. no spark to the plugs. Any advice would be most appreciated. Thanks.
Old 03-06-2005, 11:09 PM
BKFT_HOTRODER BKFT_HOTRODER is offline
The only problem you could have (If everything yousay is really good) is plugs and/or wires. tune it up
Old 03-07-2005, 06:19 PM
idmetro idmetro is offline
Re: no fire to plugs on 86 xt turbo 1.8 help
Check pickup unit voltage in distributor. Chilton or Haynes manual will describe how. Mine stopped dead in the road and had voltage coming out of the distributor but was only 4.8V and needed 12V so no spark at the plugs. A trip to the junkyard took care of the problem but be sure to take the old distributor with you as Subaru used multiple different models of distributor in this time frame.....
Old 05-06-2005, 03:16 AM
stikine2 stikine2 is offline
Under the coil is a little square chip with two wires,
some kind of condensor I think. Could be the problem. If you order one from the dealer it only comes as a set, coil,mounting bracket and condensor.
