Old 03-06-2005, 09:50 PM
musicman181 musicman181 is offline
underglow prob
i tried to search the forum by i couldnt find help.
the intructions said to hook up the red wire to the fuse. but what fuse are the refering to. where is this fuse.
civics are for suckas
95' eclipse gst
stock turbo
new C.A.I.
programmed ecu
2.0 DOHC manual
greddy bov
im workin on it. slowly but showly
Old 03-06-2005, 11:45 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: underglow prob
just a little too vague.
....It has been a LONG time...I want to move to FL or Japan.....
Old 03-06-2005, 11:48 PM
#eTurN^_d0t_ #eTurN^_d0t_ is offline
Re: underglow prob
ROFL drewh4386 nice Eclipse
Old 03-07-2005, 12:19 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: underglow prob
99% of all car electronics use 12v power, because that's what the car battery is. So when the power says to use a fuse.. use any fuse that's not being used by the engine that supplies 12 volts. Make sense?
Old 03-07-2005, 01:17 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: underglow prob
Run power from your cig lighter, your radio, or straight form the battery. As long as its Red (+), it's good
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-07-2005, 10:45 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Re: Re: underglow prob
If he is doing an underbody kit he better have a switch and NOT wire it DIRECTLY to the cig lighter.
Im assuming he isnt a complete moron and is using a switch though(but you can never be to sure)
When i installed mine 2 summers ago i ran the power from the amp to the wireless box(as it had a wireless remote). If you have an amp in your trunk i would go that way. Then you can run the wires through the small hole under the spare tire and keep everything in the trunk.
Pictures of the Truck
Old 03-08-2005, 09:02 AM
david-b's Avatar
Dave is THAT guy
Re: underglow prob
Well yeah... You need some kinda switch. Was just saying to grab power from the cig lighter.
75 Monte Carlo
Old 03-08-2005, 03:21 PM
lukedogg8706 lukedogg8706 is offline
also hope your smart enough to know you can make a switch out of the ground wire also.
98 TSI AWD
Old 03-08-2005, 08:26 PM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
Re: underglow prob
Simply run the 12 volt power cable with the inline fuse to the battery run the other end to a switch then run a power cable from your neons to the switch also, once you flip the switch they will turn on and off, as for the ground wire or black wire simply connect it anywhere on the cars frame.
Old 03-08-2005, 08:47 PM
david-b's Avatar
Dave is THAT guy
Re: underglow prob
Thats what I have. Used to be to the cig lighter. One of the wires under the car got spliced,a dn shorted oout the control box. Melted the inline fuse, and the control box caught fire. Their LEDs. I rewired all the underbodies, so there is constant +, and - is to the car. There is a switch under the cruise control to the left of the steering wheel, that turns on and off. Lights can be on when the car is off, and everything is hidden and looking good. Its all good.
75 Monte Carlo
