Old 03-06-2005, 09:06 PM
biglogonafrogbig biglogonafrogbig is offline
Leaking Antifreeze
My 88 chevy is leaking anti freeze drop by drop some where from the middle of the engine i got under there and looked but couldn't find anything i just bought it and i'm scared it might be a cracked block or could it just be a hose thanks
Old 03-06-2005, 09:23 PM
Wheeler88's Avatar
Wheeler88 Wheeler88 is offline
Re: Leaking Antifreeze
Could be a freeze plug thats leaking.
88' Chevy K1500 Silverado
350 V8 5.7
Original Owner
77,000 miles
2nd tranny
Peeling Paint - Defective Factory Paint
235/85/16 BFG MT
Old 03-07-2005, 10:32 AM
gmfan gmfan is offline
these were also noted for intake manifold gaskets, look at all 4 corners where they meet the heads, could be leaking here and running down the engine
Old 03-07-2005, 11:36 AM
broughy84's Avatar
broughy84 broughy84 is offline
88 would probably be the freeze plug above the starter. I have had to change mine in both trucks
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 03-07-2005, 11:41 AM
Is it complicated to replace the freeze plug i was under the engine yesterday but i couldn't see it is it near the oil filter thanks for the replys
Old 03-07-2005, 12:11 PM
scarberryjb scarberryjb is offline
Send a message via Yahoo to scarberryjb
Have you checked your water pump and what model is your car. On most chevy models if front wheel drive are in the back of the engine.
Old 03-07-2005, 04:36 PM
broughy84's Avatar
yes there is a freeze plug above the oil filter. this is a 350 right? either engine it has has one above the filter.
You knock the old one out with a long chisel or something and hen pull it out. I replaced all of mine with the expanding rubber type that screw in.
Matthew Brough
Old 03-07-2005, 08:25 PM
Wheeler88's Avatar
If I remember correctly theirs a total of 11 freeze plugs, 3 different sizes located all around the block, front, back and sides. The most common one to corrode out first are the two above the water pumps. I've pried them out with a screwdriver and replaced them with brass ones with some sealing goop. Hammer them in with a good fitting socket.
350 V8 5.7
Original Owner
77,000 miles
2nd tranny
235/85/16 BFG MT
