Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-06-2005, 09:02 PM
echo5 echo5 is offline
92 Dodge 250 dies and no dashlights
My 1992 Dodge Ram 250 w/ 5.9 Cummins will be running just fine and then just go dead. Whether idle or driving doesn't matter. When it dies the dashlights and radio all go out and it's just like the switch has been shut off, however door buzzer, dome light, fan all still work. After a period of time/number of tries the dashlights will come back to life and I can start the truck and go on. May happen 20 times in 30 miles or twice a day.
Old 03-06-2005, 11:07 PM
qwerty uiopas qwerty uiopas is offline
Re: 92 Dodge 250 dies and no dashlights
similar thing happened today , but with a gas 360. the truck just died and it wouldn't start for about 10 minutes. everything seamed to work radio and lights and starter. just wouldn't run, until it sat for a few minutes. then it started normal and ran great. this happens about twice a month. weather does not seam to be a factor. I'm thinking it's a mag pickup in the distributor but i don't know. Does anyone have any ideas about the problems?
Old 03-07-2005, 11:07 PM
amac209 amac209 is offline
Send a message via MSN to amac209
sounds like your ignition switch is shot. you could test it with a test light when it dies. the main ignition wire should be dark blue at the ignition switch. it might also be possible that there is a bad connection at the switch or somewhere else in the wiring
Old 03-08-2005, 10:41 PM
Have replaced the ignition switch still same problem. Any other suggestions. I'm thinking that it has to be wiring or bad relay. Where to start??
Old 03-08-2005, 11:08 PM
netmech netmech is offline
try a new battery
Old 03-09-2005, 09:15 AM
This problem is ocurring after the engine is already started running. Battery not a factor correct??
Old 03-09-2005, 01:43 PM
im no expert but a weak battery could cause some problems.. battery should read 14 volts DC
Old 03-10-2005, 10:48 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I had a (gas) vehicle where the positive cable was corroded, and it died on me.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 04-19-2005, 03:34 AM
rod mason rod mason is offline
Exclamation Re: Re: 92 Dodge 250 dies and no dashlights
You may want to check any of your anti-theft or security systems on the truck. I have a small card under the steering wheel for anti-theft. It had slightly corroded contacts that gave me fits before I remembered it was there. I simplely cleaned them with an eraser of a pencil and all was fine.
Old 04-26-2005, 07:55 PM
Talking Fixed!!!!!
Got it fixed. The problem was a fusible wire coming from the battery to the ignition switch. Just put in a new section of fusible wire and runs like a champ. Thanks to all for your help.
