Water in oil
I just recently had the heads redone and changed the oil but there is still water in the oil is there anything i can put into it to remove the water any other ideas thanks
Re: Water in oil
Just keep changing the oil until it's dry, unless the head job was flawed. You could try puting some SeaFoam in the oil, I'm thinking it absorbs water, but I don't remember if I read that on the can or if someone told me that. From reading your other post (about the leaking antifreeze) and this one, I'd say the head gaskets could have been damaged or the heads/block were warped which could cause leaking, both internal and external.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
