Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 03-06-2005, 09:02 PM
madbrad madbrad is offline
Engine running on three cylinders
I've got a '95 Mystique and just put a new head on it. But cylinder 4 is not firing.
I found out there is no power to the fuel injector. I found that the first three injectors have a common power feed but cyl. four has a different power feed. Is there a reason for this, is that injector controlled by another sensor or is it in some kind of limp mode??? I'm lost on this one. Any help would be much appreciated.
Thanks
Brad
Old 03-07-2005, 09:57 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Id check your fuel injector harness and make sure the wires arent exposed. It could be causing it to not be running at all.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-07-2005, 10:35 AM
dead cylinder
Thanks for the reply, Yes I did check that and it all looked OK. I even ran 12 volts to the injector to see if I could get it to work and that didn't even work. I did swap injectors so I do know the injector works.
