Old 03-06-2005, 07:52 PM
GSXmark86 GSXmark86 is offline
Send a message via MSN to GSXmark86
Question odd clutch problem???
I have a 98 GSX and i just rebuilt the motor and put new clutch in, etc.. When i am driving in town and using the clutch or even when i engage the clutch within a half hour, everything works fine, but when i go for more than a half hour without using it, when i go to use it, the pedal goes all the way to the floor and then i pump it a couple of times and it works just fine again. Anyone have any ideas on what my problem is? And does anyone know how to "break in" a new motor, i heard somewhere that what the owner's manual says is about the worst thing you could do... Let me know. Thanks.
1998 Silver GSX
on the road again....
Old 03-06-2005, 08:45 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: odd clutch problem???
ithink to break in a new motor, you cant engage in high speeds for at least 500 miles. and you should check so of the seals/bolts around your tranny for any leakage and maybe it just needs to be re-bled. Just some thoughts.....
....It has been a LONG time...I want to move to FL or Japan.....
Old 03-06-2005, 09:10 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
bleed the clucth better make sure you get out all the air bubbles.
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 03-07-2005, 12:18 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
check the master cylinder for leaks, also inside the firewall where the pedal connects to the cylinder.
95 Talon TSI AWD
97 Eclipse GST
Old 03-07-2005, 04:40 AM
kjewer1 kjewer1 is offline
AF - Advisor
Yes, Inside the firewall si where you check for master cylinder leaks. To check for slave cylinder leaks, pull back the rubber boot and look for fluid.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
