Old 03-06-2005, 05:56 PM
pjma pjma is offline
Question 1997 Grand Am will NOT SHUT OFF PLEASE HELP
I have a 1997 Grand am Se V6 and it will not shut off all the way the engine will shut off but the ignition will not turn back so you can get the key out. so now i lead the risk of the battey going dead what could be wrong?????????????????? Please help me
Old 03-06-2005, 07:41 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 1997 Grand Am will NOT SHUT OFF PLEASE HELP
Welcome to the forum. Is the steering column jammed?. If not you need a new igntion switch.
Edit- Also make sure the car is firmly in park. To make sure put up on the shifter while trying to remove the key.
Good Luck
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 03-06-2005, 07:59 PM
Knifeblade Knifeblade is offline
Also, jiggle the sterring wheel a bit while turning key, the wheel has a pawl that wears, which sometimes won't allow the cylinder to turn completely unless ya juggle the wheel a bit.
Old 08-24-2005, 12:57 PM
blazer165 blazer165 is offline
I had this problem as well. I had removed the pin from the gear selector to clean it and lost the pin. If the gear selector is not seated properly the rod inside will not unlock the ignition allowing you to remove key.
Hope this helps
Old 08-26-2005, 12:19 PM
Drova Drova is offline
i had the same problem almost only my ignition fried when this happened and there was a recall on it
