Old 03-06-2005, 05:34 PM
bigsteve55 bigsteve55 is offline
96 timing belt life span ??
Recently got a 96 Tracer with 1.9 l engine, with 87,000 miles on it.
Any thoughts on when I should replace timing belt as a preventive measure ? Thanks!
Big Steve
Old 03-06-2005, 07:03 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: 96 timing belt life span ??
Big Steve
autozone and ford both have webpages with recommended service intervals. I think it is 60,000
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 03-07-2005, 09:00 AM
A. Souphound A. Souphound is offline
Big Steve
Latest info on timing belt replacement has increased the interval from 60K to 100K on the 1.9L, 120K on the 2.0L Or, 72 & 84 months.
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 03-07-2005, 10:54 AM
Thanks for the replies.
Big Steve
Old 03-07-2005, 02:13 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
if its the original then replace it, i dont think it will destroy that engine if it breaks tho, some engines will.
Old 03-08-2005, 07:54 AM
sector95 sector95 is offline
Like that famous statesman C. Eastwood was wont to say;
"Do ya feel lucky... punk. Well.... do ya?"
A car with 90K on the odo is coming the end of the useful "factory recommended" life of a lot of components. The timing belt is one of them. 60K or 100K....which do you prefer? If you replace the belt now(and the water pump, too, because it's right in there with the timing belt). You *know* for sure (or at least have a very high expectation that) neither one of them is going to fail for a long time. The water pump is just a pain and will make a mess as it leaks. The timing belt can be more disasterous..... like turn the motor into garbage. I don't know if the 1.9L is an "interference" engine or not (this means that if the belt breaks and valves stay open when they should be closed, the piston *will* hit them as the engine winds down). At the very least, if the belt breaks, you're coming home behind a tow truck.
How lucky to ya feel?
Mike
Old 03-08-2005, 02:57 PM
TheStang00's Avatar
the 1.9 will not do that if the belt breaks... id know... if u catch my drift
Old 03-11-2005, 03:29 PM
Davescort97 Davescort97 is offline
Escort guy
If your timing belt breaks it will not jam the valves into the top of the pistons. I had a belt break at 100,000 miles and it didn't damage the engine.
This was on the 95 wagon with l.9 L engine. But, why pay to have it towed. Replace the belt.
Old 03-11-2005, 08:51 PM
panzees36 panzees36 is offline
Send a message via Yahoo to panzees36
I had 2 timing belts break, at different times of course, on a 1993 and engine was fine both times.
Old 03-13-2005, 12:53 AM
bj21 bj21 is offline
My timing belt's teeth stripped at about 100k.
No engine damage.
Don't forget to replace the water pump at the same time.
Old 03-15-2005, 02:02 PM
B REAL B REAL is offline
Send a message via AIM to B REAL
50 or 60 thousand miles
Old 03-15-2005, 02:03 PM
im pretty sure the 1.9 is a non interference engine.. meaning if timing if off you piston wont collide with valves and all that jazz
you still gonna have a problem tho, spark knock, hot spots, multiple detinations...........
