Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-06-2005, 04:28 PM
Justinjj727 Justinjj727 is offline
Send a message via AIM to Justinjj727 Send a message via Yahoo to Justinjj727
Angry Fuel Pump installation help
Alright 93 3.8L... the old fuel pump was on its way out had a slight rough idle and the pump was making noise. i bought a new one installed it and all it does now is go up to 1500 rpm the falls down roughly and die..... did i do something wrong? better yet that fuel tube thing that goes into the pump, does that have to go inside the pump tube or just put it in there with its rubber bushing thing? thats how it seemed to come out??? help plz
Old 03-06-2005, 04:29 PM
Re: Fuel Pump installation help
also if u could hit me up on aol [email protected] or aim same sn! very much appreciated! thanks
Old 03-06-2005, 05:36 PM
ok i just dropped the tank agian took it out and reinstalled it same problems. if i try to put it in gear it dies, it still goes up to 1k..... its not the injectors and its not the fuel filter it was running fine before i did the fp its just the old one was on its way it. started making the death hum and just barely started to idle ruff!
Old 03-11-2005, 05:01 PM
Ok back agian! took the old(new) pump out turns out it wasnt for a 93 but for a 94 because the new one i bought today looks just like the old one! still having the same problem, plugged the battery back up and now the thing still doing the same stuff..
Old 03-11-2005, 08:29 PM
97Bird's Avatar
97Bird 97Bird is offline
Check your codes for a clue to your problem.
Old 03-13-2005, 08:34 PM
no codes! check engine light doesnt come on either.... i ordered a fuel sending unit. ya kno the thing that holds the pump and has the metal fuel lines and what not.... hopefully that will fix it!
