Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-06-2005, 05:28 PM
xcusememisswyn's Avatar
xcusememisswyn xcusememisswyn is offline
Send a message via AIM to xcusememisswyn
speaker installation
how hard is it to put new speakers in the car... a 1996 s14 SE, i got new 6.5s but i read somewhere i would have to put new holes in to mount them... is this tru
RB20DET, 260whp, Drive to Destroy.
Old 03-06-2005, 07:40 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: speaker installation
yeah they need some custom work. i had my install guy cut out pieces of some wood fiber shit or whatever it was and mount my speakers on that cause the stock ones aren't 6.5". atleast they werent in my s13. take it to any mobile audio shop and they'll do it properly cause its tough to do without the right materials and tools. i'd also reccommend dynamat. which, if you didn't know, deadens vibrations from the speaker going into the door.
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 03-06-2005, 10:13 PM
how much can i expect to pay at an audio place?
runnin a little low on money
Old 03-06-2005, 10:38 PM
also, does anyone know how to get to the speakers in the rear... are the panels inside supposed to pop off b/c i was havin a hell of a time findin a way... i think once i could get the old speakers out i could find a way to get the new ones in, im just havein a hard time gettin to the old ones
Old 03-06-2005, 11:36 PM
Mayday0017 Mayday0017 is offline
you can change the speakers yourself, don't pay anyone they are easy. Then again I did car audio for a living for the past 4 years. Ummm... door pannels are easy to get off and you don't have to custom make anything they fit right in. If they are a really deep mount you might have to cut the back out of the plastic piece they screw to but that's it. as far as the rear there are some 8mm or 10mm nuts that hold down the rear deck you access them from the trunk or by folding down the seat then it comes off and you can get to the speakers. Also you need to do a rewire to bypass the amps if you have them in your car, they are located under the rear deck viewable from the trunk also. If you need any help just take a pic of the door and the underside of the trunk and I'll tell you where all the screws and everything are and how to do it.
Old 03-07-2005, 12:31 AM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
You need to bypass the amps just for installing new speakers?
Old 03-07-2005, 12:36 AM
wgfinest3 wgfinest3 is offline
this is y im happy my bro is a prof. installer cause i dont have to kno sh*t about this i jus say hey do this and he does...like right now were rolocating my cd player in the middle of the dash on the passenger side cause we replaced the stock spot wit a tv and were takin out the glove box and he is buildin a custom panel for a ps2(i kno i kno its kinda ricey but hey i got the tv for 50 bucks and the ps2 for free so i figure what the hell!!)
Old 03-07-2005, 08:07 AM
It depends on the resistance that the amplifier is designed to run at. Whenever I do 240's insted of running all new wire because it is time consuming I go to the drivers kick pull it up cut the speaker wire in half the goes to both front speakers, run a section of wire from the radio to the half of each wire that runs to the front then I connect another short section of wire to the rear half of the front speaker wire, then I go to the amp and cut the front output wires off the amp and connect them to the rear output, That way I don't have to run hardly any wire and it is very easy to reverse if you deside to go back to factory.
Old 03-07-2005, 10:28 AM
SHIFT_KA24DE's Avatar
SHIFT_KA24DE SHIFT_KA24DE is offline
don't waste too much money on sound systems that's all i got to say...
btw mayday.. is that your zenki? it's hot.
Old 03-07-2005, 11:25 AM
More for MayDay
so i cant run them with the factory amps at all, or is there some way i can tell if they are good for the speakers i got? also if i have components for up front do i have to rewire for the crossovers or can i run them from what wires are already there..? If i have to use the crossovers where is the easiest place to wire them and place them...
thanx in advance
sorry im new to all this
Old 03-07-2005, 11:52 AM
D-Bo's Avatar
i'd say take out the crossovers. normally new speakers have them built in. and mayday, i had new speakers installed (6.5) and they didn't fit into the stock location.. maybe the s14s came with 6.5 stock instead of 3"..
Old 03-07-2005, 01:21 PM
yah but i mean the SE came stock with tweeters and i was wondering if that wiring was good for the new tweeters or if i had to redo it wit the crossover the new speakers came with...? do i even need the new crossovers?
Old 03-07-2005, 01:32 PM
D-Bo's Avatar
why don't you buy 2 in 1s? they have tweeters in them.. but i guess you may have already bought new speakers.. what i did was left the old tweeters, and unhooked them.. now i have 6.5 2-ways in my doors, and they work perfectly.. no external crossovers or anything. direct wiring..
Old 03-07-2005, 02:10 PM
S14 has 6.5" all the way around that is why you don't have any cutting needed. As far as your components good choice they will provide a better sound quality then a coaxel speaker is capable that is why they cost more. take off the door pannel, pull the rubber gromet out of the door and piller then run your wire through it and into the car shouldn't be to hard then run it up to your radio leaving I would say 6" of slack now mount your crossover in the passenger kick cut the wire you ran right by the crossover and now you have 2 wires ran the one for the midbass and the one for the input all that is left is to run your tweeter, now grab on to the top of the piller the tweets go in and pull it will come right off from here you will see the factory used like rubber coated metal wire like twist ties to secure the factory wire, since it's there go ahead and use it it should go down to the kick anyways so hook that up and repeat on the other side. Also don't waste your $$ on components for the rear because your going to end up with the same sound a coaxel would provide and more trouble hooking them up.
Old 03-07-2005, 02:12 PM
Thanks Shift, the car is/isn't mine yet. My friend had bought it like 2 years ago and a couple of us worked on it and suggested things well now he's selling it and I'm buying it just waiting on him to get it down here since he's moved to austin which is like 9 hours away.
