Coolant levels................
got a `99 EXT montana. This past week the coolant light has been go on and off. So i check the reserve tank and its empty. So i add a mixture of coolant and water. I check it today (4 days later) and the reserve tank is dry again. Im not seeing any puddles and spots on the driveway. Is this the dreaded head gasket issue? I havent checked around the engine compartment for leakage. I only have 68k miles.
2000 Grand Prix GT w/ gold package. K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe 2004 Chevy Trailblazer EXT Keep on Keeping on... |
Check your oil, dipstick and filler cap, for milky oil greyesh crap. you might have the leak
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80 2004 Chevrolet Impala LS 3800 "ALWAYS"...... full synthetic!!!
Re: Coolant levels................
I can see it on the engine but not where its actually leaking. Its more towards the drivers side. Its wet around the oil pan and on up. Its got that well known orangish color. If its leaking around the back gasket than thats a problem. Front one is more managable.
It's your lower intake manifold gasket. I just replaced mine and it's a major pain in the butt. It's a well known issue with these engines and it's about a 1000.00 dollar job at your dealer. If you keep driving it you will eventually destroy your engine so don't let it go to long. Good luck.
i just did a search on it and theres a thread about contacting pontiac and they will replace the gasket for $100 since they know its a known problem.
will the Bars radiator stop leak work? They also make some Head Gasket leak stop too.
Re: Re: Coolant levels................
Thanks. |
