Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-06-2005, 04:40 PM
j-johan j-johan is offline
2000 Maxima Stalling during idle
Hi:
I have been having a problem for the past few weeks with my 2000 maxima. The car will start fine, but after it warms up it will stall. I can restart and let it idle a few minutes and it will stall again. The check engine light is not on and when I had it checked there were no fault codes.
I have:
- Cleaned the throttle body
- replaced both upstream O2 sensors
- Checked most of the sensors
- I have about 1.7VDC out of the mass airflow sensor at idle
I also have a problem with hesitation during acceleration. When I hard accellerate, the RPMs go up but the car feels like it is being held back.
I have checked the output from the TPS and get about .5-4VDC when I push the throttle.
Anyone have any suggestions??
J
Old 03-06-2005, 08:21 PM
thrasher thrasher is offline
Boy does that scream fuel pump, or fuel delivery of some sort. Check out the fuel pump first, I bet that's it.
Old 03-07-2005, 03:22 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 2000 Maxima Stalling during idle
Originally Posted by j-johan
Hi:
J
How many miles, when/what was last service?
During warmup ECU uses the TPS. Then TPS is used only by TCU =auto transmission, and O2 sensor(s) input to ECU come in place of TPS.
Coolant Temp sensor ok? Plugs swap time, Ign coils leaking, injectors time is up. Check/swap all Filters.
MAF: should have linear voltage increase as u open throttle, engine running.
TPS resistance, engine off, meas from connector: linear resistance increase while throttle is turned.
And as already mentioned: fuel pressure.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 03-10-2005, 11:51 AM
infinman infinman is offline
huh?
Old 03-14-2005, 07:37 PM
street_racer_00's Avatar
street_racer_00 street_racer_00 is offline
Sounds like a fuel blockage of some sort....replace the fuel filter or run a bottle of fuel injector cleaner in your next tank of gas.
2000 Nissan Maxima SE, autotragic, sterling mist
My Max: Getting smoked by boosted cars since 2004
2004 AF award winner: longest time period w/o posting an actual street racing story
Originally Posted by CassiesMan
I got to see boobiues!
Old 04-15-2005, 06:44 PM
geneb22 geneb22 is offline
My Maxima is doing the same thing, the mechanic says it's probably an idle air control valve but can't guarantee that if he replaces it that it'll fix the problem and I'm not sure that I want to spend $450 for him to experiment.
Old 05-10-2005, 11:38 AM
bratfry bratfry is offline
See my post about what I did to my Idle control value. (Idle control value question) It was about a 15 minute job and the car is like brand new, well almost. I am going to get a new one when time and money permits.
Old 05-11-2005, 04:15 AM
Re: Re: 2000 Maxima Stalling during idle
Originally Posted by bratfry
See my post about what I did to my Idle control value. (Idle control value question) ...
So where is that? pls copypaste here...
VGE IACV cleanup is easy, on VE theres more work. Some do it by squirting cleaner spray into IACV air input hose; needs attached extension hose bit with a small hose to squirt intake cleaner spray in while idling. Surely helps; functional operation cannot be verified, cleaning is not perfect, and all soot that is let loose, gets into engine (not too bad). I would rather do that than do nothin.
Old 05-11-2005, 08:55 AM
The post is on this forum under "Idle air control value question". I cleaned the entire throttle body. Its not that hard of a job to take off and clean good. It didn't fix the cut out at idle speed. I then took the idle air control value off, two(2) screws and the wire harness and sanded the value tip with 600 sandpaper, just to see what would happen, it helped a lot, a real lot. Of course now I should buy a new one to really fix it. List price is $240 and discount is $180. Still a lot of money.
Old 05-17-2005, 05:00 PM
Sorry I have not replied lately, been out of town.
I have done most of the items listed, thanks for all of the replies. However, the car is still stalling. I broke down and took it to the Nissan dealership. They said they did not know what was wrong but wanted to charge me an arm and leg to replace the idle air control valve.
I found a used one on Ebay and ordered it (about $30) I also took the throttle body apart, cleaned it real good, and reassembled according to Nissan specs (I downloaded a service manual for the 2000 maxima from Phatg20.net).
Bottom line, it is NOT the iacv or any type of setup in the tPS. The stepper motor in the iacv works perfectly. The used iacv I ordered from ebay works exactly like the one in my car.
My next step is to disassemble the fuel system, clean it out good, and possibly replace the pressure regulator and damper.
I have made one discovery, however, the stall at idle only happens when the throttle closed switch is activated. If I just move the throttle a bit off the closed position the car will not stall.
Old 05-18-2005, 03:07 AM
...I have made one discovery, however, the stall at idle only happens when the throttle closed switch is activated. If I just move the throttle a bit off the closed position the car will not stall.
There must be a airleak. Take all small hoses out for inspection, bend them (lots of hoses); intake seals leaking. Search out with water, some try starter gas (rpm rises if gas gets in -and- water temporarily seals a leak)
How about PCV?
TPS affect only when cold.
Old 09-13-2006, 11:51 AM
sero73 sero73 is offline
Did you ever solve the problem? I have the same problem. Thanks.
Robert
Old 01-03-2008, 11:03 PM
roa roa is offline
Hi was this problem ever resolved?
