**98 Z24 Headlight Problem**
I have a 1998 Cavalier Z24.
A couple of days a go I noticed my driver side headlight was out. I went to the store to purchase a new one, installed it and it still didn't work. Shortly after I realized that the bulb I thought was burned out really wasn't. WTF. Tested all bulbs and all work fine. So my dad and I decided to dig a little further. Here's what is happening; Headlights OFF: Daylights work fine, Highbeams work fine, Foglights work fine ON and OFF. Parking Lights ON (1st notch): Daylights work fine, Highbeams work fine, Foglights work fine ON, however driver lowbeam lights up very very very dim. Headlights ON (2nd notch): Highbeams fine, Passenger lowbeam fine, Driver lowbeam does not work, Passenger foglight ON fine, Driver foglight ON does not work, Foglights OFF both are dim. What a freakin' mess!!! Does anyone have any suggestions? Help is much appreciated. Thanks, Lu. |
wiring harness?
interior light switch on the column? everything worked fine a day or 2 ago
just noticed my DRL indicator is flashing as well...
Head lights
Check the DRL relay. Mine went and caused the DRL light to flash. Also a sound from the fuse box could be heard. The relay was clicking on and off.
Re: **98 Z24 Headlight Problem**
Hi veeko, did you find a solution to your headlight problem? I am having the exact same problem.
Fog lights shouldn't be "on" when you don't have any lamps on. But your problem sounds like it could be as simple as a corroded ground.
1992 Chevrolet Cavalier Z24 *R.I.P.* 3.1L MPFI (3.1 6cylinder Pushrod 12V) 1997 Chevrolet Cavalier Z24 *R.I.P.* 2.4L "Twin Cam" (2.4 4cylinder DOHC 16V) 2003 Honda Accord EX V6 - The new hotness |
