Old 03-06-2005, 02:54 PM
1SweetRide 1SweetRide is offline
'91 Cherokee Trans
I'm having a problem. When under a load it "Bucks"
like an old mule.Figure it needs a rebuild.Any ideas
as to how expensive this is?
Thanks,
Bryan
1990 Maxima SE & 1994 Ford Aerostar XL
Old 03-07-2005, 05:28 AM
Cam7 Cam7 is offline
A rebuild will usually run around 700 if you take the trans out and install. The bucking could be engine related make sure it is the trans before installing a rebuild. What speeds does it act up and and does it act up in all the gear ranges?
Old 03-07-2005, 06:42 AM
Seems mostly about 25-30.Sometimes if I take my
foot off gas to coast.Thanks for the info.
Bryan
Old 03-08-2005, 04:22 PM
Po Pilot Po Pilot is offline
Send a message via ICQ to Po Pilot Send a message via AIM to Po Pilot
Re: '91 Cherokee Trans
Sounds like the TCU might be shot. The AW4 goes into "maunual" when that happens - almost like towing a battleship right?
Try this: Start off in 1st. Then when you reach what you think is another shift point then put it into 2nd. If it doesnt buck then you know that the TCU is shot and not the tranny. You get the TCU at any junk yard for cheap.
Old 03-09-2005, 07:25 AM
Forgive me,what is the TCU?
Thanks,
Bryan
Old 03-09-2005, 02:43 PM
Transmission Control Unit.
Located up under the dash on th passenger side. Little box.
Old 03-10-2005, 12:11 PM
Which side?
Thanks,
Bryan
Old 03-10-2005, 01:37 PM
Which side?
On the passenger side.
