Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-06-2005, 12:34 PM
lumpydink lumpydink is offline
VCT Solenoid problem ??
I have a 98 Contour 2 Lt. The check engine light has been on and off for about one year. I have recently had the timing belt changed,(car has 135,000 km on it) but since then, the check enging light is still on, and now when ever I put my foot on the gas, I get a hesitation. I was told that the VCT solenoid sensor ($600) needs to be replaced. Could it be that the timing belt was installed improperly. Is there a test that could be done to find out just what the problem may be, without having to mortgage my home ??
Old 03-06-2005, 09:52 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
unplug the vct plug and see if it still happens
Old 03-08-2005, 10:14 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: VCT Solenoid problem ??
do you know what the code is?? chances are the solenoid or the wiring were bad before. if the code is for over advanced/ under advanced timing they screwed up while changing the timing belt. trust me belts on these are a real pain to replace. the vct solenoid sucks to change too you need to remove the timing belt and the exhaust camshaft. the price is 3.8 hours labor. unpluging the connector won't make the light go off because the computer will see the winding in the solenoid as being open.
Old 03-09-2005, 07:30 AM
Banned
i ment to see if the problem still occurs, i know that it will still throw a cel
