Old 03-06-2005, 12:27 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Question i need specs
I need to know how many ft/lb tq to tighten the head, intake manifold and exhaust manifold on a D15b vtec. Im thinking it should be the same as the Z6 motor. Also just as important…I use all the gaskets and timing belt from the 92-95 z6 …right?
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 03-06-2005, 05:37 PM
Scott82 Scott82 is offline
Re: i need specs
Torque specs
Cyl Head bolts.- first step= 22 ft lbs,
second step= D15Z1 & D16Z6= 53 ft lbs
D15B7 & D15B8= 49 Ft lbs
exaust man. to head=23 ft lbs
intake man. to head= 17 ft lbs
Not sure about the gaskets or timing belt though. Hope it helps
Old 03-07-2005, 08:52 PM
thanks
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
Old 03-07-2005, 08:59 PM
travagliante's Avatar
travagliante travagliante is offline
Re: i need specs
z6 for top end gaskets and t-belt and d15b7 (5th gen dx, lx) for bottom end.
Old 03-07-2005, 09:26 PM
Re: i need specs
thanks thats all i needed to know im gettin stuff tomarrow after school, puting it all togather and than off to find the obd1 converion and a harness for the motor (vtec or non vtec, ill just run a wire)
almost there!!!
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
Old 03-07-2005, 09:45 PM
Re: i need specs
wohoo!!! What ecu are you running? P28 or P30? Dont forget to wire the knock sensor!
Old 03-07-2005, 09:56 PM
Re: i need specs
<[email protected]> Shoot this guy a message, he probably have the conversion harness you need. He has a ebay store and sells the jumper harnesses, if you talk to the guy he'll give ya a pretty good deal.
