Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-06-2005, 11:50 AM
bumpit2001 bumpit2001 is offline
Won't Start
My friend has a 97 gs and it won't start. He's getting no power to the coil packs. We've replaced the crank sensor and we've checked the cam sensor, and the cam sensor is good. but it starts some times and runs for a few seconds and dies, the longest its ran is 20 min. What esle do i need to do, we are about to go crazy. Please Help!
Old 03-06-2005, 04:21 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Won't Start
The only thing left that I Can think of is the ECU itself (bad ignition drivers?) or a break in the wiring that opens up intermittently. When its not starting I would try to ohm out the wiring if you can get a good schematic.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-06-2005, 07:21 PM
Unhappy testing an ecu
thank you very much.
Now I was wondering if there is a way to test the ECU my self with an ohm meter or something before I send it off to get tested. Any help would be appreciated.
Old 03-07-2005, 06:22 PM
matth matth is offline
Re: Won't Start
If you have any friends with a dsm you might ask them if you could take out thier ecm and put it into yours then you will know if it is the ecm. But thier is a way to test it without taken out I realy do think if you did a search you would find out how. Case I have looked for it before and found it on this forum. But if you do have to replace it they have the ecm at advance auto for $250 conpared to the dealers $1200 so good luck hope I helped
Old 03-31-2005, 01:21 AM
Does anyone know where I can get a good schematic besides the Chilton book, because we have now replaced the ecu, asd relay, and the fuel pump relay, and we still have the same problem. So we believe it could be the wiring. Any help would be appreicated.
Old 04-03-2005, 10:02 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
Re: Won't Start
check the relay.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 04-12-2005, 09:14 AM
Clipsa Clipsa is offline
I was having the same problem w/ my 98 eclipse-we were doing just a simple head-gasket and the dang thing would not start back up- ended up changing the ignition switch, the relay for the starter, every other relay imaginable except the fuel pump relay. We finally gave up and had a well-known shop come pick it up. It was that fuel pump relay. We swiped one off another eclipse from their junk yard and worked good for a few weeks- had to finally break down and buy a new one- havent had a problem w/ starting since. Although I have a slow start- I heard it was the line to the fuel pump has to much slack? Any feedback on that?
Good luck- ps fuel pump relay is located on firewall- the chilton book and hayes books do not show you where this relay is- we had a heck of a time!
Old 04-19-2005, 03:34 PM
all relays r good we put all new ones and swapped them around and everything. thank you can you think of anything esle
Old 10-07-2005, 04:46 PM
can anyone help this car is still busted its been almost 1 year
Old 01-10-2006, 05:40 AM
Amplituned Amplituned is offline
Re: Won't Start
Hey, if you want a good wiring Diagram, you can always go to a mitsubishi dealership and ask the service department to print you up one. Or, it sounds stupid, if you know anyone at a shop that has a Mitchell on demand or Alldata programs. Even alot of Tech schools have them now too. People can be schools can be ***holes sometimes, but for the most part they are willing to help ya out. hope that helps.
