Go Back   Automotive Forums Car Chat > Suzuki > Samurai
Old 03-06-2005, 09:39 AM
jerryor58 jerryor58 is offline
Battery won't charge
My battery on my 88 Samurai will not charge thru the alternator. I have replaced the alternator/Voltage regulator, checked all wiring required by service amnual and nothing checks out bad. In the owners manual it states, "If your battery does not charge for no spicific reason, contact your authorized repair facility". Can anyone give me any ideas?
Old 03-09-2005, 01:40 AM
ben50520012000 ben50520012000 is offline
Re: Battery won't charge
have you done a voltage check from you alternator to the ,
maybe your battery is dead or you have a bad ground
allso if you have a stero running and a amp or kc light , the littel 40 amp alternator will not keep you battery charged becuase you are drawing to many amps
-ben
Old 10-19-2005, 12:04 PM
PJRaces11 PJRaces11 is offline
if you a running a amp and kc lites or a bigger stereo they sell a kit to help you you can get it at rocky-road.com and its the brackets and hardware to mount a gm alternater which is way bigger puts out way more amps i would suggest this
Old 01-11-2006, 02:11 AM
greenhorn greenhorn is offline
Switch to thicker positive and negative main wires, the thin ones have to much resistance if your running a lot of electrical equipment, but the bigger alt is also agreat idea and if you ever plan on a dual battery system it's essential. Check all your grounds first though.
Old 05-22-2006, 08:49 PM
teemsta teemsta is offline
I put a volt gauge on my zuk and when the gauge showed a no charge or reading around just 12 it was always because the belt wasn't tight enuff. some how the belt would loosen up on me over a peiod of time. so I would have to adjust the tension on the alt. hoe that helps.
p.s. I had a 88 1/2 brand new back then for about 10 yrs and a took that thing apart from front to back. what a great machine those were. I sure do miss mine. it had a 4 inch calmini lift with 33' tires and a header with no cat. funny thing now is my bro just bought a 88 off ebay that has only 9000 miles on it. jealous lol
Old 05-10-2013, 12:16 AM
Tami.P Tami.P is offline
If alternator id good then check connections, clean off and use wire brush. Check battery water. Check the connection of cables.
May be there is any problem in one of them.
marksoldtowne
[link removed by moderator]
