Old 03-06-2005, 08:04 AM
czm400r czm400r is offline
99' Front wheel hub
I have a 99' Blazer 4x4 and had the left front hub changed about a year and a half ago. I am getting the same Vib. from the other front now. If I was to replace it myself what am I in for and do I need to have the front end aligned again?
Old 03-06-2005, 12:48 PM
ricksza's Avatar
ricksza ricksza is offline
Re: 99' Front wheel hub
Alignment is not necessary. You will have to remove caliper, rotor, and axle nut & washer. Then unbolt the hub assembly off the steering knuckle. You will have a wiring harness coming off the hub for the ABS wheel speed sensor.
Old 03-06-2005, 12:50 PM
Thank You, I will give it a try
