Old 03-06-2005, 08:02 AM
krumrei krumrei is offline
93 Caravan Transmission problems
Ok,
My issue is this. I have a 3.3 V6 93 caravan.
I recently replaced the Solonoid for the tranny, flushed everything out, everything looks fine, but the transmission will sometimes shift fine, but aother times, it will only go into 2 gear, until I pull over, restart the motor like 3-6 times and then it will finally go into low and then shift normally.
Sometimes when I start the damn thing will not even go into gear. I check the valve body for dirt, clean, replaced the solonoid, does the same damn thing. Check and clean all the sensors with electrical cleaner.
I am thinking it maybe an electrical issue/computer.
Anyone else have this probelm?
Old 03-31-2005, 12:26 PM
rebuilder rebuilder is offline
Re: 93 Caravan Transmission problems
Originally Posted by krumrei
Ok,
for your van not to go in gear is a mechanical problem,unless you have no fluid in it.when a chrysler trans goes into limp in the realy is turned of and line pressure is at maximum.They will always go in gear if there is an electrical problem.
