Old 03-06-2005, 07:21 AM
fwagner fwagner is offline
Send a message via Yahoo to fwagner
running hot
Help me please my car if i let idle for minute runs very hot all the hoses are fine does anyone have a idea of what it could be or where i can find a book to try to repair it myself please help anything would be great
Old 03-06-2005, 07:33 AM
public's Avatar
public public is offline
Re: running hot
Bad fan motor/relay or thermostat.
Yes, I am retarded.
Old 03-06-2005, 08:15 AM
Relay?????
Ok now i know im looking stupid but what is the relay and where is it. How can i locate it and how do i fix it is this gonna be expensive
Old 03-06-2005, 01:02 PM
public's Avatar
Re: running hot
First, determine what is bad. Does the fan come on? If so then the motor and relay are okay. At what temp does the fan come on? if it is too high then you could have a bad temp sensor. The relay is cheap. Follow the wires from the fan motor, they go to the relay. Last one I bought was $11 at AutoZone. Good Luck.
Yes, I am retarded.
Old 03-06-2005, 01:23 PM
TunerAdept TunerAdept is offline
Re: running hot
could also be the water pump
2005 2.2L Ecotec Cavalier LS Sport Manual 145hp/155tq
K&N Ram Air Intake "Typhoon Intake"
*comming*
upper/lower poly mounts
header 4-2-1 1.5 primaries
remote exhaust cutout/ hi flow cat/ hi flow muffler/ larger piping
Racing Spec grounding kit
-----then the fun mods start, but one step at a time-------
Old 03-08-2005, 07:14 AM
Re: Relay?????
Ok well i cant figure out where the relay is its still running warm and the fan and pump are fine is there anything else it can be
Old 03-08-2005, 04:08 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Re: Relay?????
you need to check the thermastat then. If the hose coming off the top of your Rad is not getting hot then your T-stat is stuck closed. From the sounds of it this is your problem. I would also suggest that you get a Haynes or Ciltons manule for your car. It will help you find alot of different things on your car.
Old 03-08-2005, 04:14 PM
BDD2003 BDD2003 is offline
Send a message via AIM to BDD2003 Send a message via Yahoo to BDD2003
Re: Re: Relay?????
I have this problem with my Cav too. I drive an 04 now and it still does it when I leave it idle for a long period of time. I have never been able to figure it out but it will go back to normal after driving again. When it was happening to my 98, the thermostat had to be changed.
Old 03-08-2005, 09:58 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: running hot
fan motors in these things go bad all the time. the fuse and relay are located in the power distibution center, its the big fuse block on the left fender. there should be a 40 amp maxi fuse, if it is blown chances are the fan motor is bad. if the fan is working check for blockage of the ratiator(leaves, mud etc.) if that looks fine there might be a problem with the thermostat or water pump as mentioned above or blockage in the cooling system. another cause of overheating is a blown head gasket/ cracked head, a shop can test for this with a chemical test of the coolant. good luck!!
Old 03-09-2005, 11:55 AM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
Re: running hot
You never said what car you have, also if the miles are high the radiator could be clogged, I know mine is, damnit.
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
Old 03-10-2005, 08:53 AM
Re: Re: running hot
1998 cavalier sedan need help
