type r or gsr
i know the type r has 195hp to the crank, and the gsr has 170hp, so which car is the better project car. the type r or the gsr.
Re: type r or gsr
search
Re: type r or gsr
If your buying the engine, I'd go with the GS-R. The only difference in the engine is cams and pistons which will be changed out anyway if your building it up.
If your buying the whole car, I would go with the Type R. Better in almost every way. |
Re: type r or gsr
It really depends on what you are going to use the car for.
Re: Re: type r or gsr
Re: Re: Re: type r or gsr
here's my deal. i curently have a 2001 eclipse rs(slow as f**k) and im wanting a different car. and i know nothing about acura or honda, all of my knowlege is towards eclipses. so i was wondering if anyone could help, or guide me along.
Re: type r or gsr
IF you are going to leave it stock, get the ITR, it's kind of like modifying a Lamborguni (sp?), It is the b est of the best from the factory. If you are going to mod it, then go with the LS or GSR. GSR for n/a and LS for turbo.
[quote=b18ls]The only difference in the engine is cams and pistons which will be changed out anyway if your building it up.
QUOTE] No, the moling is different, the GSR is duel IM runner, and IMO, it doesn't flow as well. The GSR cams are not as hot, and the comp are also not as hot. |
Re: type r or gsr
this is only what i would do so use it or not this is just what i would do i would find a 94LS obd1 for some were around 5g's the money i would have saved from not buying a type R i could build and boost and hope to see high 12's low 13's if your in to drag racing anyway
Re: type r or gsr
i read in a book somewhere that the itr doesn't handle bolt-on's as well as the gsr, is this true.
it will handle them just as well, difference being though that the type R already has freer flowing better engineered parts than the gs-r therefore you would see a bigger gain from an intake on a gs-r than on a type R BUT the type R already has a 25 more Hp stock soo you do the math. for example: 170+5 or 195+3 you choose
Old: 1993 Acura integra gs-r New: 1998 chevy BlaZeR2~ AKA "Jeep recovery device" Newer: 2007 Honda CB900F "919" |
Re: Re: Re: Re: type r or gsr
possible I suppose BUT the Type R has a much better suspension and an LSD in the tranny so even if you make the gs-r faster it will still not have the handling characteristics of the R.
Also, The Itr Is 1000 Lbs Lighter Than The Gsr. If You Don't Care About Additional Accessories Like Cruise Control, Sunroof, Etc, Than The Itr Is Something To Look Into, I Actually Think The Type R Looks Better Without All The Extra Trim, But I Do Love My Extra Accessories.
