Old 03-06-2005, 12:08 AM
djkdawg djkdawg is offline
accord 1990 problem with shifter
aight this is not a stick shift car it is a automatic, but you know it drives fine for like 10 minutes then all the sudden , the enginge stays on and u can ram it up all u want to but the car will not move, then when i cut it off and put it in park, start it back up it will move for a while but then mess up again. what is wrong please help
Old 03-06-2005, 07:57 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: accord 1990 problem with shifter
Well, checking your fluid level sounds like a good place to start....
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 03-06-2005, 11:47 AM
i dont know what it is, it is filled to the tip top
Old 03-06-2005, 06:36 PM
lorunner lorunner is offline
Probably a trans. Sounds like there is debris in the trans and when you drive it gets sucked up into the internal screen and causes the pressure to drop. once you shut it off the debris settles and then the car will move again untill it gets clogged again.
Stop asking me about radio codes I cant get them anymore!!!
Old 03-06-2005, 07:31 PM
how do i fix that ?
Old 03-07-2005, 06:08 PM
mpumas mpumas is offline
Change the oil in the tranny. It is easy and replacement fluid is not expensive. If that doesn't fix it, you might need a new tranny.
